March 8, 2023 at 6:58 am
Mohammadreza Hojati
SubscriberHi everyone. I have designed a BLDC using RMxprt. Creating a 2D model from RMxprt, the software automatically creates an inverter circuit for the model, to drive it. In this circuit, there are 3 ammeters to measure the current passed through each phase of the motor. But, I want to measure the current passed through each switch of the driver. I added an ammeter after each switch, but I do not know how to see the measured current in my 2D motor model. In results, I can see only the phases currents. I have named them S1,S2,... and their label are Switch1, Switch2,... . Could anyone tell me if I have done it correctly, and how I can see their results as well?
March 22, 2023 at 12:56 pm
HDLI
Ansys EmployeeHello Mohammadreza,
    First, after modifying circuit, we need to export netlist and impot it back into Maxwell to update external circuit.
    In transient result plot, we should see BranchCurrent in Category. If not find, I suppose you do not import new circuit.
Howard
April 24, 2023 at 7:41 am
Dastrm Nasrt
SubscriberCould someone confirm that I did it right and explain how I may access their findings, too?
- The topic ‘Measuring current passed through switches in a BLDC driver (ESC)’ is closed to new replies.
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
3862
1414
1220
1118
1015
