March 6, 2024 at 1:53 pm
March 7, 2024 at 6:10 am
Keyur Kanade
Ansys EmployeeYou can select 2 entities like 2 points or 2 faces and it automatically gives distance at the bottom.Â
Or you can create planes at the desired locations and then measure distance between them.Â
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
March 8, 2024 at 7:55 am
paul pladet
SubscriberHello Keyur,
The box i made below is the workaround i used and i do know you can easily meassure this. Its the fact however that i even have to create a subsitute to meassure the tube whats the issue. It would be nice that i could meassure the total length of the tube without adding any geometry.
March 8, 2024 at 8:01 am
Keyur Kanade
Ansys EmployeeYou just need 2 points. You can use Split option to split edges of that tube. Then select those 2 points and you will get the distance.Â
Please go through help manual for more detailsÂ
Keyur
March 8, 2024 at 8:04 am
March 8, 2024 at 8:13 am
paul pladet
SubscriberHello,
As shown in the image below, splitting the edges does not give me the correct total length:
When i do use move i can ofcourse allign it to the XYZ and this would work, but lets say you have 50 tubes in a document. I'll have to do this 50 times, which takes a long time to do. it would be nicer if we could use Alt or so to allign the measure tool to the object.
March 8, 2024 at 2:01 pm
Keyur Kanade
Ansys EmployeeScripting might help here. But I am not scripting expert. Please open a new thread for scirpting and somebody will reply.Â
Keyur
- The topic ‘Measure total length Tube’ is closed to new replies.
5969
1307
