TAGGED: ansys-fluent, boundaries, cfd, udf-fluent, velocity-inlet
February 18, 2022 at 10:19 am
isaps1860
SubscriberI have a room with an inlet for fresh air and additional a person in the room who is breathing. Now if I compile and load the Age of air UDF with DEFINE_DIFFUSITY and DEFINE_SOURCE the code is working but the code runs for both inlets. The fresh air inlet which I want the code running and the breath Inlet of the person in which I don´t want the Age of air in it. Is it possible to give one inlet the UDF scalar and an other Inlet not?
Best regards
February 18, 2022 at 11:38 amRob
Forum ModeratorYou'd typically run the MAA UDF on a frozen flow field after running the model. So in that case change the mouth to a wall and then run MAA. The flow field is unchanged but the scalar won't see the second inlet.
February 18, 2022 at 11:49 amisaps1860
SubscriberThank you very michViewing 2 reply threads- The topic ‘Mean age of air (MAA) with 2 inlets’ is closed to new replies.
5674
1890
1419
