May 21, 2025 at 5:39 pm
mika.loiselle.1
SubscriberHi,
Do you know if MCalibration can be used to calibrate materials for dynamic tests like impacts? Or is it just for traction or compression tests? I’m trying to make a TPU model for impact simulations and I was wondering if I could use impact tests as calibration data to make sure the model is as accurate as possible since it is a nonlinear hyperelastic material. Do you know if that software can allow us to do that? -
May 22, 2025 at 1:06 pm
Ram Gopisetti
Ansys EmployeeHi Mika,Â
MCalibration can target the specific solver to build a fully calibrated material model that is compatible with LS-Dyna. For thermoplastics, MAT_318 (TNM_PLASTIC) is an ideal choice, and it can be calibrated using MCalibration by inputting temperature- and strain rate-dependent tension-compression test data, along with creep curves (optional). Additionally, you may explore other material model frameworks offered by LS-Dyna, such as MAT_317, MAT_24, and MAT_168 (for brick elements), among others, for thermoplastics.
Cheers,Â
RamÂ
May 22, 2025 at 1:20 pm
mika.loiselle.1
SubscriberHi,
Thank you for your reply. It helps a lot. By "straint rate-dependent" data, do you mean something like multiple uniaxial tension tests at different strain rate or do I need data from a test with variable strain rate like a dynamic drop test where I would use something like the acceleration as data?
Thanks again for your time,
Mika
3140
1007
935
858
792
