March 5, 2020 at 9:49 pm
ATournilhac
SubscriberHello,
IÂ 've created a Synchronous Machine model from Rmxprt and everythings works properly. But when I want to switch to the full machine (Maxwell propose to simulate just symetrical fraction of the machine), each parameter is correctly duplicate except damper bars.
This is really weird, Is anyone had the same problem ?
Thanks
March 14, 2020 at 4:34 am
Navya Chode
Forum ModeratorHi,
Before you analyse the RMxprt model, go to RMxprt > Design settings > User Defined Data > Check Enable
In the text window type "Fractions 1" with out quotation marks (capital F).
Then Analyse the RMxprt model and create the Maxwell model by right mouse click on Analyse > Create Maxwell design.
This should generate the full machine Maxwell modelÂ
February 2, 2021 at 7:43 am
hamid1
SubscriberThanksn
- The topic ‘Maxwell2D Model from RMxprt – Issue when swiching fraction to 1’ is closed to new replies.
Ansys Innovation Space
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
1414
1256
1118
1015
