TAGGED: 3d, ansys-maxwell, hollow-conductors, transient
August 4, 2021 at 2:15 pm
forsyth307
SubscriberI am having trouble getting ansys maxwell to simulate hollow conductors for a large 3D model with transient solution type. The error , including grammatical issues, is as follows:
"Source setup is incorrect. Please make sure the sum of currents in each full winding must be zero in the both stationary moving region, respectively."
Below is an attached image of an example single conductor's geometry. I have shown one full conductor with its coil terminal excitation plane visible (both set to transparent), as well as one extra coil terminal excitation plane that visualizes the current vector.
August 5, 2021 at 5:56 pmAugust 9, 2021 at 6:23 pmViewing 2 reply threads- The topic ‘maxwell trasient 3D hollow conductor source excitation error’ is closed to new replies.
4728
1565
1386
1242
