Electronics
Electronics
Maxwell temp files
    • juhani.stenback
      After trying to run two Eddy current (3D) analyses simultaneously, I saw that Maxwell uses excessive amounts of disc space from my C drive even though I have set the temp file directory on a different drive. The allocated space is freed when the simulation ends or is aborted, so they seem to be temporary files only. Why is this, and how can I prevent this? What does the "override" box do?
    • GLUO
      The results data file is saved in a folder next to your .aedt project file. Is your .aedt file also in C drive?
      GL
