April 10, 2024 at 2:46 pm
Luca Moleri
SubscriberHi.
I am trying to import a step generated in Onshape file into Maxwell, but I get the following error:ÂÂ [error] Import Native Bodies: Translation of "xyz.step" failed. (05:29:17 PM Â Apr 10, 2024)
 ÂCan you please help me to identify the problem?
Thank you
April 11, 2024 at 8:35 pm
HDLI
Ansys EmployeeHello Luca,
   Could you save as the CAD file into sat format when using 22R2 or lower version? and parasolid format for higher version?Â
HDLI
April 15, 2024 at 4:58 am
Jason Cao
SubscriberHi HDLI,
I encountered the same problem. I save my model as parasolid(.x_t) and still failed to import it into electronics desktop.
Seems like it's a common problem. Is there any solution?
Thank you
April 14, 2024 at 7:59 am
Luca Moleri
SubscriberHi, yes, I can produce that. The problem is that in the Modeler I see that I can import only DXF or STEP files. Is that because I am running on Ansys Electronics Desktop Student 2023 R2? Is there another solution?
Thyank you
Luca
April 15, 2024 at 5:08 am
Jason Cao
SubscriberHi Luca,
I just solved my problem. Please make sure that your file path is 100% in ENGLISH letters. For example, simply move the file to under C:\ or F:\, whatsoever.
I am from China so many folders are named in Chinese characters. The problem solved as soon as I moved the model file to D:\.
Hopefully this will help:)
Regards.
April 15, 2024 at 5:57 am
Luca Moleri
SubscriberHi Jason.
Thank you for the suggestion, but that is not the case for me.
Best regards
Luca
- The topic ‘maxwell step import failure’ is closed to new replies.
5944
1307
