June 10, 2022 at 3:24 pm
yinan
SubscriberHi! I encountered some problems when using Ansys Maxwell to do the simulation of a power electronic transformer, which is a 30kHz power ferrite transformer. The simulated core loss is only about 1/4 of the experimentally measured value and the winding loss is only about 1/2 of the measurement value. Has anybody encountered the same problem before? Is there any specific examples of Maxwell power electronics transformer loss simulation that would be helpful? Thank you!Â
June 28, 2022 at 6:03 am
NKC
Forum ModeratorHi Yinan,
Are you performing 2D or 3D simulation?
If you are performing a 2D simulation, have you set the correct model depth under the design settings?
Navya
- The topic ‘Maxwell power electronics transformer simulation’ is closed to new replies.
Ansys Innovation Space
- Lumped Port Deembed
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
1420
1272
1119
1015
