TAGGED: -Ansys-Maxwell-electronics, fem, generator, losses, power
June 17, 2025 at 4:57 am
2diamondm
SubscriberHello,
I’m running a 2D transient FEM simulation of a linear generator using ANSYS Maxwell. The simulation runs without any error or warning, but I’m facing a problem related to energy conservation and inconsistencies between different software versions.
Main Issue:
In ANSYS Electronics R2022, I observe:
Output power: 95.95 W
Input power: 99.33 W
Losses (Core + Solid + Coil): 6.129 W
→ Total (Output + Losses) = 102.08 W, which is more than the input, violating energy conservation.
In Maxwell 14.0 (same model):
Output power: 96.05 W
Input power: 100.28 W
Loss values were not available, but overall energy behavior was more consistent.
Simulation Details:
Software: Maxwell 14.0 and ANSYS Electronics R2022
Model: 2D linear generator
Motion: Translational, Global Z, ±5.5 mm stroke
Speed: Constant at 1.727 m/s
Time step: 0.1 ms
Simulation time: 80 ms
Excitation: 220-turn coil
Circuit: R = 24.925 Ω, C = 226 µF
Boundary: Vector Potential = 0
Input power: Force_z × Speed
Output power: Current × Voltage
BH curve material: 35PN230 (nonlinear)
Losses used: CoreLoss, SolidLoss, StrandedLoss
Additional Notes:
Increasing the time step from 1 ms to 4 ms caused output power to drop (96 W → 84 W), showing time-step sensitivity.
Mesh refinement had little effect on the output at 1 ms.
In a second test, increasing the magnet thickness (3 mm → 3.8 mm) gave a more realistic result (Input > Output + Losses).
Questions:
Why does output + losses exceed input power?
Does R2022 compute losses differently compared to Maxwell 14?
Any help or insights would be appreciated.
Best regards,
Muhammad Mohsin
3266
1031
1004
859
798
