Electronics
Electronics
Maxwell: Error: The current flow in/out the region alongside the terminal.
    • Alanood Alharthi
      I am trying to make helical antenna and receiver to measure the mutual inductance. For some reason, the analysis will not work. It carshes with the message: The current flow in/out the region alongside the terminal.
      I am unsure how to proceed.
      Kind regards
    • Alanood Alharthi
      For anyone facing the same issue, I have fixed it myself. What was missing was a region. So the steps are:
      1- Create a region
      2- Make the terminals touch the border of the region
      3- Make sure that the borders of the terminals and region meet, zoom in and make sure
      4- Lastly, add a matrix and tick on both the transmission and reciever antenna
      Hope this helps, if you need more I recommend these two videos:
      https://www.youtube.com/watch?v=L_Wa5prjPMk&t=496s&ab_channel=Andr%C3%A9Radu
      https://www.youtube.com/watch?v=Ej4-er33Z3M&t=2s&ab_channel=kamyarK
  • The topic ‘Maxwell: Error: The current flow in/out the region alongside the terminal.’ is closed to new replies.
