August 29, 2018 at 7:39 am
Mr.T1993
SubscriberHello all,
I am trying to simulate the losses in an induction motor with a script in Maxwell 2D transient simulation. The calculation with the script returns the iron losses, the current and the flux linkage. However ANSYS always gives me after a certain time the error
"Failed to copy local file C:Usersen71003DocumentsAnsoftMaxwell2D_6DTemp Aux559.dat to file C
TEMP/PH/PMSM.aedtresults/Part_Motor.results/DV11534_SOL3506_V11411.Field11447/solution.txt.
ERROR: The process cannot access the file because it is being used by another process."
Has anyone ever had the same error message and can help me? I'm happy for any help and thanks in advance for your help.
Viewing 0 reply threads
- The topic ‘Maxwell: Error Message Core Loss in Induction Motor and Fluent Coupling’ is closed to new replies.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
1487
1358
1189
