February 14, 2022 at 10:24 pm
JacobT
SubscriberHello,
I'm trying to get a map of the electric field generated by a current-carrying flat coil on a parallel plane a short distance from the coil. I'm using Ansys Maxwell Eddy Current solver with the free student version.
February 18, 2022 at 8:10 pmHDLI
Could you reduce scale of E field and maybe plot E in all the surfaces or in the object ? It seems that you just plot the E in bottom surface of the object, that might have low values.
HDLI
Viewing 1 reply thread- The topic ‘Maxwell Eddy Current: Electric Field from Coil’ is closed to new replies.
5944
1307
