July 12, 2023 at 2:18 pm
Kyrylo Kalashnikov
SubscriberI am trying to create a pulse for a curent excitation. The way I want to do it is to define a dataset ds1,and make the excitation equal to a variable Amp_1= pwl(ds1,time). However, when I make the value of the excitation equal to Amp_1, I get an error 'Current can not be a function of intrinsic variable 'Time'. Could someone advice me how to proceed with this issue?
July 14, 2023 at 2:39 pm
GLUO
Ansys EmployeeHello,
Are you using transient solver? If yes, could you try using pwl(ds1,time) as current instead of a variable?
GL
- The topic ‘Maxwell: Current can not be a function of intrinsic variable ‘Time’ Error’ is closed to new replies.
