Platform
Platform
Topics related to optiSLang, HPC, DesignXplorer, Cloud and more.
Maxwell 2D 2-way coupling with Steady-State Thermal
    • q.qin
      I am setting up a 2D 2-way coupling simulation between Maxwell and static thermal simulation in Workbench using 2025R1 version.
      I can get 1 way coupling results (Maxwell to Steady-State Thermal). But I cannot get temperature feedback to my Maxwell even with the help of the Feedback Iterator.
      I have added thermal modifer and enabled temperature feedback in Maxwell.
      However, I cannot find 'export after solve' or 'Export' in my Steady-State Thermal for 'Import Load'
      I am following this setup:  https://ansyshelp.ansys.com/public/Views/Secured/Electronics/v242/en/Subsystems/Maxwell/Content/CouplingMaxwellDesignswithANSYSThermalviaWorkbench.htm
      According to the user manual for the above link, the 2-way coupling between Maxwell and Steady-State Thermal should work.
      But I also found https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/corp/v242/en/wb_sim/emag_temp_results_export.html?utm_source=chatgpt.com
      It shows exporting these results does not supported by 2D mechanical analysis. So I am very confused.
      Would someone please let me know:
      1. Is it feasible for 2D 2-way coupling between Maxwell and Steady-State Thermal?
      2. If not, would it be possible to manually input/link the thermal distribution in Maxwell?
      3. If yes, are there any hidden bottom or processes that need to be taken, and have I possibly missed?
      Thank you
Viewing 0 reply threads
