June 10, 2021 at 4:35 pm
bugrrasen
SubscriberI am doing harmonic piezoelectric analysis in Ansys 2021 workbench, when I make precision mesh for piezoelectric bodies, I get this warning on the solution screen. Do you think it's an important warning ?
"The maximum contact stiffness is too big. This may affect the accuracy of the results. You may need to scale the force unit in the model."
June 21, 2021 at 5:16 am1shan
Ansys EmployeeYou may want to check the contact tool results and see if they look OK. If there is no sign of abnormality you can safely ignore the warning.
Regards Ishan.
Viewing 1 reply thread- The topic ‘Maximum contacts stiffness is too big.’ is closed to new replies.
3572
1188
1076
1063
952
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
