March 15, 2024 at 9:52 am
Purinut Lersnimitthum
SubscriberI tried to use matrix27 as spring element and I changed the spring joint in workbench to Matrix27 by the code below (element type 4 is spring joint element)
/PREP7
et,200,MATRIX27
KEYOPT,200,2,2
KEYOPT,200,3,4
KEYOPT,200,4,1
R,200,34411799,136089343,0,0,0,0,
RMORE,-34411799,-136089343,0,0,0,0,
RMORE,232106005,424813159,0,0,0,0,
RMORE,-232106005,-424813159,0,0,0,0,
RMORE,0,0,0,0,0,0,
RMORE,0,0,0,0,0,0,
RMORE,0,0,0,0,0,0,
RMORE,0,0,0,0,0,0,
RMORE,0,0,0,0,0,0,
RMORE,0,0,0,0,0,0,
RMORE,0,0,0,0,0,0,
RMORE,0,0,0,0,0,0,
RMORE,34411799,136089343,0,0,0,0,
RMORE,0,0,0,0,0,0,
RMORE,0,0,0,0,0,0,
RMORE,0,0,0,0,0,0,
RMORE,0,0,0,0,0,0,
RMORE,0,0,0,0,0,0,
RMORE,0,0,0,0,0,0,
RMORE,0,0,0,0,0,0,
RMORE,0,0,0,0,0,0,
esel,s,type,,4
emodif,all,type,200
ALLSEL
/SOLUThis is simple spring and mass system. The point mass attached to small 2D plane strain area at which the MATRIX27 also connected and MATRIX27 connected to 2D plane strain square area where it was subjected to displacement excitation.
and the result of harmonic response is zero for the entire range of the frequency for both the x and y direction. I would like to know how to fix this.
Thanks.
March 18, 2024 at 3:46 pm
Chandra Sekaran
Ansys EmployeeI did not check your R definitions but one thing I noticed is you are changing the TYPE to 200 with emodif command. But you also need change the real ID to 200, don't you? Like 'emodif,all,real,200' for the matrix27 properties to take effect.
March 18, 2024 at 7:03 pm
SubscriberMany thanks, the problem is solved????.
- The topic ‘Matrix27 in harmonic analysis workbench’ is closed to new replies.
