April 29, 2021 at 12:43 pm
fparveen
SubscriberHello,
I am getting the following error for a simulation. Can anyone suggest why is this happening?
process hf3d error: Matrix solver exception: file I/O failure. Please contact ANSYS technical support
May 3, 2021 at 12:25 pmPraneeth
Please let us know what version of the tool are you using and also provide some screenshots of the error.
Are you getting this error for only one model or you are not able to solve any model?
All the very best.
May 11, 2021 at 7:20 amfparveen
SubscriberHello I am using version 2020 R1.
I am getting this error when there is not enough RAM space to solve the system. I tried to simulate the design with a different computer with bigger RAM, there it simulates without any issues.
Thanks.
May 11, 2021 at 12:10 pmPraneeth
Thank you for letting us know that you were able to solve your issue.
Best regardsDecember 3, 2021 at 8:05 pmmohamedakmal
Subscriberthis error is show
when change RAM .this error show
[error] Solving adaptive frequency ..., process hf3d error: Matrix solver exception: file I/O failure. (9:45:55 PMDec 03, 2021)
[error] Simulation completed with execution error on server: Local Machine. (9:46:18 PMDec 03, 2021)
how can solve it?
December 6, 2021 at 6:10 amPraneeth
Please use "upload image" to share your screenshots as Ansys employees cannot access the attachments across the forum.
Best regards.
February 22, 2023 at 2:12 pmMary Mary
SubscriberDear, fparveen
Please, how do you resolve this problem? I have a computer with a lot of RAM, but I'm getting RAM errors.Â
Viewing 6 reply threads- The topic ‘Matrix solver exception: file I/O failure. Please contact ANSYS technical support’ is closed to new replies.
Innovation SpaceTrending discussions- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
Top Contributors-
4167
1487
1358
1188
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
