October 14, 2019 at 5:44 pm
ATIKADAR
SubscriberI am trying to interfacing between Ansys Fluent and Matlab. I can run my Fluent simulation via Matlab. Now I am trying to calculate mass weighted average temperature of a volume and I have used this Matlab codeÂ
iFluentTuiInterpreter.doMenuCommandToString('report volume-integrals mass-avg (channel) temperature n')
This code can measure the temperature and can print the value in Matlab command window. But now I want to save this value in another variable so that I can use this number in post-processing. I am trying to use this command
iFluentTuiInterpreter.doMenuCommandToString('define variable pick report volume-integrals mass-avg (channel) temperature n')
but its not working. Can someone please help?
Thank you.Â
October 17, 2019 at 10:51 am
Forum ModeratorThe first command looks to be pretty much the text user [TUI] command we'd use to get the mass average temperature in the channel volume. That will be output the Fluent TUI window. Where do you expect the second command to store the data?
October 18, 2019 at 11:10 pm
ATIKADAR
SubscriberYes. you are right. First line is basically a journal command and it works fine in Matlab. For the next command, I would like to save the temperature value in a variable-
X=iFluentTuiInterpreter.doMenuCommandToString('define variable pick report volume-integrals mass-avg (channel) temperature n');
I want to save the computed value in the variable X?
October 22, 2019 at 1:17 pm
Forum ModeratorIf you put that command into Fluent what happens? Just the Fluent part of it to check you're using the correct Fluent TUI command.Â
October 22, 2019 at 3:13 pm
ATIKADAR
Subscriber(define x (pick-a-real "report/surface-integrals/mass-weighted-avg (outlet) temperature n"))----this journal works fine in Fluent and it store only the number is the variable x. I want to do the same in via Matlab.Â
October 23, 2019 at 1:08 pm
Forum ModeratorYou want the Fluent value that's reported into Matlab for manipulation in Matlab?Â
October 23, 2019 at 10:51 pm
ATIKADAR
SubscriberYes.Â
October 25, 2019 at 1:58 pm
Forum ModeratorGiven the value has been taken from Fluent and displayed into Matlab won't you be better off asking on a Matlab forum? Please post the answer back into this thread.Â
- The topic ‘Matlab-Fluent Interfacing’ is closed to new replies.
- affinity not set
4402
1494
1376
1209
