October 30, 2021 at 11:05 am
ss_stardust
SubscriberHi,
I am trying to download MATLAB Fluent AAS toolbox for Ansys Fluent 19.2 from customer portal with the help of video provided by Ansys on Youtube. However, when I click on the link for solution number 2042389, it shows 404 error.
Please instruct how can I download the toolbox. Also, if there is some other way to connect MATLAB with Fluent, please suggest.
Thanks in advance
November 1, 2021 at 11:35 amKarthik Remella
AdministratorHello I attempted to open the referenced solution on the Customer Portal and it seems to be working okay. Could you please give this a shot again?
Instead of clicking on a link, please log into the customer portal and search for the solution number. Please let me know if this works for you.
Karthik
November 1, 2021 at 12:59 pmNovember 1, 2021 at 1:08 pmNovember 1, 2021 at 1:32 pmRob
Forum ModeratorCan you open the link in the solution? The Portal has been flagging that warning for a while as IT have been moving things in the background. The links tend to work OK.
Some of the solutions will work in later releases, some don't. Fluent AAS is also covered in the manual to some extent.
November 1, 2021 at 1:43 pmss_stardust
SubscriberHi When I click on the link, the page opens for a blink and goes to 404 error shortly after. I am in dire need of this toolbox. Please help.
Thanks.
November 1, 2021 at 2:43 pmNovember 1, 2021 at 3:25 pmss_stardust
SubscriberHi Thanks for the prompt reply. Can u suggest what may be the reasons under which such issue can arise? Is this restricted for certain licenses?
November 1, 2021 at 4:04 pmRob
Forum ModeratorPortal is accessed by anyone with the right level permissions. There are tiers above "user level" for staff and other linked companies but I'm not aware of any difference in a "client" usage. Can you ask your supervisor or ASC to try it?
November 1, 2021 at 4:42 pmRob
Forum ModeratorEdit - I've removed the link as it looks like it's our side that's not working. Staff credentials work fine, but client level don't. Web services are on the case, so please try again in a day or so.
Note, I am not (legally) permitted to share the files so your patience is appreciated.
November 1, 2021 at 5:56 pmss_stardust
SubscriberThank You for prompt replies and action. I hope issue gets resolved as soon as possible.
November 3, 2021 at 11:20 amRob
Forum ModeratorTry solution 2057025 The solution you had was marked as obsolete but still showed up on the external list for some reason.
November 6, 2021 at 8:53 amNovember 8, 2021 at 9:39 amRob
Forum ModeratorI assume you have a aaS_FluentId.txt file?
November 8, 2021 at 10:01 amss_stardust
Yes, I do have the file. Please refer to the picture attached in previous comment. You can see the mentioned file in the current folder on left.
November 8, 2021 at 12:34 pmRob
Forum ModeratorOK, is going to have a look when he's out of training. Not necessarily today though.
November 15, 2021 at 1:26 pmss_stardust
SubscriberHi Any update regarding the error I am getting?
November 15, 2021 at 1:58 pmspatel
Ansys EmployeeHi,
It does appear thereÔÇÖs an updated toolbox presented as a Solution on the Customer Portal:
#2057025 - ANSYS as a Server Example: MATLAB Setup (Matlab R2014b-R2020b)
I.e. Solution Number 2057025
Best regards Samir
November 15, 2021 at 2:12 pmNovember 17, 2021 at 5:46 amss_stardust
Subscriber, I figured out my mistake. Thanks for the help.
Viewing 19 reply threads- The topic ‘MATLAB Ansys Fluent AAS toolbox’ is closed to new replies.
5694
1891
1419
