January 8, 2019 at 8:20 pm
balsaidi
SubscriberWhen I wrap 3D material over certain model it becomes 2D shell!Â
Is there any technique to follow such that I can keep the same 3D material even after wrapping it?Â
Thanks,
Bashir
January 9, 2019 at 2:00 pm
jj77
SubscriberI am not 100 % sure what you are trying to do.
Any images along with some detailed explanation would be help me and perhaps others understand.
January 9, 2019 at 8:10 pm
January 9, 2019 at 9:25 pm
Sandeep Medikonda
Ansys EmployeeBashir, Did you un-select Delete source geometry and try?Â
Also, not that it will fix things but can you upgrade to 19.2 and try?
Sandeep -
January 9, 2019 at 10:02 pm
balsaidi
SubscriberHello Sandeep,
would you please explain to me how to delete source geometry? Not sure why or how?
Do you think R19.2 handles wrap feature in better way?
Thanks,
Bashir
January 9, 2019 at 10:55 pm
Sandeep Medikonda
Ansys EmployeeBashir,Â
In the first image you posted under Options (on the left), I see that it is checked. Just uncheck it.
I can't comment on one feature as I would have to go over all the release logs but in a general sense, there are a lot of features, stability and robustness you are missing out on if you 5 releases behind.
Sandeep
- The topic ‘Material’s wrapping’ is closed to new replies.
- BackGround Color
- Contact stiffness too big
- Element Birth and Death
- Python-Script to Export all Children of a Solution Tree
- Which equations and in what form are valid for defining excitations?
4597
1495
1386
1209
