November 16, 2020 at 11:07 am
Luigi0
SubscriberHi,nIn engineering data, when I select anisotropic elasticity, why I don't need to specify the poisson ratios?n -
November 16, 2020 at 8:51 pm
Luigi0
SubscriberI clarify the question: why when isotropic or orthotropic elasticity are selected, poisson ratios must be specified, whereas in the case of anisotropic elasticity poisson ratios are not required?n -
November 17, 2020 at 12:56 am
BenjaminStarling
SubscriberWith anisotropic elasticity, the poissons ration is defined through the ratio of normal strain between two variables (x - y, y - z, z - x).nPlease see this post /forum/discussion/comment/59558#Comment_59558n
- The topic ‘Material’s elasticity’ is closed to new replies.
