November 22, 2023 at 4:32 pm
javat33489
SubscriberDoes Ansys GRANTA have graphs for the identification of materials? For example, tensile rubber? How to find them?
November 24, 2023 at 9:26 am
David Mercier
Ansys EmployeeHi! What do you mean identification of materials. Graphically speaking, in all Granta products (EduPack/Selector, and MI), it is possible to plot material properties in a x-y chart, which is usually named Ashby chart, material property chart or bubbles chart (see below). Such charts based on performance indices help you to determine the best material for a specific problem. It is possible as well to rank materials (in a table for example), to plot links between materials records (in MI), or to plot materials data in any type of chart (barchart, pie...etc) using pythn routine (pyAnsys for MI for example).
November 24, 2023 at 9:28 am
David Mercier
Ansys EmployeeConcerning rubber, there are plenty of data (multiple records) depending of the reference database you are using in Granta products. And you can find rubber materials by setting up some criteria (composition, material family, properties... for example) or you can find them using keywords in a search bar.
November 24, 2023 at 4:12 pm
javat33489
SubscriberI need tensile and compression test curves.
November 24, 2023 at 7:31 pm
David Mercier
Ansys EmployeeYes in the Jahm and Materials Data for simulation subset of MaterialUniverse: https://www.ansys.com/products/materials/materials-data-for-simulation
November 25, 2023 at 7:29 pm
javat33489
SubscriberCan I find material test curves in the Granta EduPack program?
November 26, 2023 at 11:19 am
David Mercier
Ansys EmployeeYes the Material Data for Simulation subset (containing stress strain and fatigue curves) of MaterialUniverse is included in Granta Edupack (level 3). But please remember that Edupack is for educational purposes only.
November 26, 2023 at 12:48 pm
javat33489
SubscriberI couldn't find any test curves (tension or compression) there. How to find them there?
November 27, 2023 at 9:32 pm
David Mercier
Ansys Employee-
November 28, 2023 at 4:11 pm
javat33489
SubscriberThis way it will show me all the materials that have test schedules. Right
November 28, 2023 at 4:35 pm
David Mercier
Ansys Employeeyes
November 28, 2023 at 4:40 pm
javat33489
SubscriberOk. Thank you!
- The topic ‘Material testing schedules’ is closed to new replies.
5899
1306
