August 16, 2023 at 6:14 pm
August 17, 2023 at 6:28 am
Sampat Kumar
Ansys EmployeeHiÂ
Are you facing this problem for assigning the material in all the parts or it's just for the specific part that you have highlighted?Â
Please let me know
Sampat -
August 18, 2023 at 1:56 pm
dusev
Subscriber-
August 21, 2023 at 3:37 pm
Sampat Kumar
Ansys EmployeeHi Dusev,
Will you please use the material assignment option? Are you facing the same issue by right click on the material and selecting the material assignment option? if you still face this issue then select the None option in the mechanical view tab in the Engineering data.Â
Click file --> options--> UI option--> Engineering data--> select None.Â
Please let me know if you are able to assign the material or not.Â
Sampat
- The topic ‘Material Selection Missing After Loading Custom Engineering Data (AnsysWBU box)’ is closed to new replies.
