January 27, 2025 at 5:07 pm
p.wilk
SubscriberHello guys,
I am trying to make a custom RVE Model in Material Designer. I do only have a .xdme or .stl file. Now I opened the .stl file in SpaceClaim and 'ConvertSurface -> To Solid'. Then I copied the entire body (2 Phases) into Material Designer but when I try to assign the different phases I do get an error:Â
This is the Phases:Â
Is it possible that the error is because I have around 50 solids for 1 Phase and 70 for the other Phase? Does it have to be just one solid? Does anyone have an idea how to fix this? I think it is because of a faulty material assignment, I used custom Tungstencarbide engineering data because I couldn't find one in my materials. Any idea how I might get the correct WC material Model? I have the material in ansys Discovery but somehow not in Engineering Data.
Kind Regards,
Philip -
January 29, 2025 at 7:38 am
Akshay Singh
Ansys EmployeeHello Philip,
I have found a resource related to your issue. Please go through it and review its contents carefully specially the Notes and see if it resolves your issue.
https://innovationspace.ansys.com/knowledge/forums/topic/material-designer-how-to-use-material-designer-for-a-custom-rve-with-multiple-phases/
February 4, 2025 at 3:40 am
- Shape Memory Alloy Deployment
- Correct Material Definition
- Explicit Dynamics Material properties
- Get ultimate strength value from simulation
- Softening Issues in Reinforced Concrete
- Material Designer – Material Assignment
- Error on Material Designer, One or more errors occurred.
- Material Designer, Different warp and weft shares in woven RVE
- how to use Plastic material property of steel only
- Hydrogen Simulations
2773
960
835
599
591
