TAGGED: airfoil, aoa, drag, flapping-wing, lift, lift-coefficient, naca-airfoils
May 24, 2023 at 10:18 am
marco.peviani
SubscriberHi everyone, I have a NACA 4410 profile which I have done an analysis at different AoA (parameterizing the AoA) to find the CL and the CD. Now I want another run but with a 2410 with flaps, matching the lift from the first analysis to get the flap angle to have the same LIft.
For example I have the 4410 at 5° of AoA and I find that the CL is 0.93, now with the same CL I want to find the Flap angle (of 2410).
How can I do ?
Thanks in advance -
May 24, 2023 at 12:43 pm
Federico
Ansys EmployeeHello Marco,Â
you can set up a parametric simulation with the AoA as your parameter using Workbench. Set a range values expected for the AoA and run through these points until you approach the desired value.Â
May 24, 2023 at 12:51 pm
marco.peviani
SubscriberThanks for the reply, but my problem is related to the matching of the CL without going to trial and error also because for this project I have to do various simulations and it would take a lot. Would it be possible to have AoA as output variable matching the CL?
- The topic ‘Matching the Lift in order to calculate the flap angle’ is closed to new replies.
- affinity not set
3862
1414
1221
1118
1015
