Electronics
Electronics
Matching boundary process fails
    • fatii
      Please, how to fix this problem on ansys Maxwell : ''Matching boundary process fails''
    • Mark Christini
      The geometry on the Master and Slave faces must be identical, to 16-decimal places.  When creating a partial model, you must be very careful.  Once created, use Model > Measure in the Maxwell modeler to check that vertices on master and corresponding slave location are at exactly same rotated or extruded location.
  • The topic ‘Matching boundary process fails’ is closed to new replies.
