October 23, 2024 at 10:37 am
October 24, 2024 at 9:32 am
harshvardhan.negi
Ansys EmployeeHi,
Match control in meshing has certain limitations. I think it might help you to cross verify if what you wish to do is compatible with it.
You can find the help document on Match Control below:
Match Control
I hope this helps.
Harshvardhan
Ansys Help
Ansys Learning Forum (Rules & Guidelines) -
October 25, 2024 at 7:29 am
akm019
Subscriber''=areaAve(Pressure)@rotating * area()@rotating'' it is correct expression for calculating load carring capacity of bearing in ansys result table
1307
