October 16, 2024 at 10:25 pm
ggege0524
SubscriberHi,Â
I'm trying to apply a match control to my mesh in ANSYS Fluent, so I can latter use periodic boundaries, but it doesn't seem to be working. I always get the same error: "At least one body has no elements...". I thought, that maybe something is wrong with my geometry, since I imported it as CAD model. But then I tried this with just a simple cuboid, see below, and it is still not working. What should I do?
October 22, 2024 at 12:28 pm
Federico
Ansys EmployeeHello,Â
Cyclic match control is meant for rotational periodicity about the z-axis of the defined Coordinate system. For a cube, you will need to change to Arbitrary Transformation
Ansys Innovation Space
1013
956
858
797
