October 18, 2024 at 6:11 pm
valerym.m5
SubscriberWill it be possible to use model 318 for EFG, SPG, SPH formulations ?
October 18, 2024 at 6:14 pm
valerym.m5
SubscriberPreviously, when using the polymod library, it was possible to use the following parameters:
ODE solver id (ODE)
Jacobian calculation method (JAC)
Varying these parameters often helped solve the tasks.
in the latest version LS-DYNA (318 model), these parameters are not available.
Will they be available in future versions of this model?
If these parameters are not available, it would be useful to understand:
1. Why did they become unavailable to users?
2. What values ​​of these parameters does the program use "by default"? -
October 18, 2024 at 9:03 pm
valerym.m5
Subscriberhere is another example where the problem is solved using "old" external models from the library PolyUMod and an old version of ls-dyna.
Six_Absorber_1.2_Dr-3_Initital-TNV_Mortar-TNM.key
https://drive.google.com/file/d/12PuM3x4Dzhp3kP6pHU9Tbw-PexEOB1JG/view?usp=sharing
the same model is not solved in the new version of ls-dyna, where the built-in material model 318 is used
0_05.key
https://drive.google.com/file/d/1pJViLRThhYFLWui1N7erdZcY6pacPz_D/view?usp=sharingÂ
$# Material Model: PolyUMod-Three-Network (Mat318)
https://drive.google.com/file/d/14B60mxRfUwm-M6VeuTtMSjAgqwcm2jqT/view?usp=sharingÂ
 E r r o r  t e r m i n a t i o n               10/18/24 23:35:12
forrtl: severe (157): Program Exception – access violation
Image        PC         Routine       Line     Source       Â
lsdyna_dp.exe    00007FF787286B82  TET_FORCEU        5728  dyn38.F
lsdyna_dp.exe    00007FF787325C9E  TET_SLD1IP        4407  dyn38.F
lsdyna_dp.exe    00007FF7899E87CB  SOLDE           1694  dynpe.F
lsdyna_dp.exe    00007FF7841299EF  FEM3D_DO235        2977  fem3d_a.F
lsdyna_dp.exe    00007FF784128F2D  FEM3D_DO235D       2705  fem3d_a.F
libiomp5md.dll   00007FF92CFB81D3  Unknown        Unknown  Unknown
libiomp5md.dll   00007FF92CF06E97  Unknown        Unknown  Unknown
libiomp5md.dll   00007FF92CF081F1  Unknown        Unknown  Unknown
libiomp5md.dll   00007FF92CEC2754  Unknown        Unknown  Unknown
lsdyna_dp.exe    00007FF784128003  FEM3D_DO235D       2672  fem3d_a.F
lsdyna_dp.exe    00007FF7840EEAF6  FEM3D           9738  fem3d.F
lsdyna_dp.exe    00007FF7840E6D78  SOLTN           441  fem3d.F
lsdyna_dp.exe    00007FF7842225D8  OVERLY           277  dyn0.F
lsdyna_dp.exe    00007FF782DA47BF  LSDYNA1          965  dynm.F
lsdyna_dp.exe    00007FF782DA4129  MAIN__          2060  dynm.F
lsdyna_dp.exe    00007FF790E63BE2  Unknown        Unknown  Unknown
lsdyna_dp.exe    00007FF79181BC08  Unknown        Unknown  Unknown
KERNEL32.DLL    00007FF9A70E257D  Unknown        Unknown  Unknown
ntdll.dll      00007FF9A884AA58  Unknown        Unknown  UnknownÂ
