Preprocessing
Preprocessing
Master Slave Node in Work Bench
    • jatinder mohan
      We are user of ANSYS APDL, recently we have performing an analysis using ANSYS workbench. We want to create master slave node in workbench like we use to do it in ANSYS APDL. We facing difficulty in creation of  independent node itself in work bench. Any one can help by providing some litrature to create the same.
    • mrife
      Hi jatinder
      What is the purpose of the 'master slave node'?  WB Mechanical will auto-create the necessary nodes/elements for many of the reasons an independent node is needed (and tied in some way to the FEM).  It's possible that you do not need to create this manually.  Mike
  • The topic ‘Master Slave Node in Work Bench’ is closed to new replies.
