August 5, 2017 at 1:24 am
nauroze
SubscriberI have a lattice that has elements which are not regular for example it looks like dipoles arranged like this
how can i make a unit cell for this structure and assign boundary conditions.
Viewing 0 reply threads
- The topic ‘Master/Slave boundary conditions for irregular FSS’ is closed to new replies.
Ansys Innovation Space
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
1414
1241
1118
1015
