January 9, 2025 at 4:04 am
jijojose2024
SubscriberHii all,
When I tried hand calculation for the temperature of exhaust gas cooled using mCpdt equation it is found that mass weighed avg is within 1 or 2 deg of the hand calculation but most tutorials and some opinions i personnaly got says it is area weighed avg to get the temp at the outlet of an exhaust pipe.Â
so which one is correct??
January 9, 2025 at 10:53 am
Forum ModeratorFor flow boundaries I'd use mass weighted (except for pressure) and for solid surfaces it's generally area weighted. For the flow bc you need to account for the (small region) of high velocity flow carrying a larger proportion of the mass/heat/species.Â
January 27, 2025 at 4:16 pm
jijojose2024
Subscriberbut why most tutorial videos suggest area weighted average??
January 27, 2025 at 5:05 pm
Forum ModeratorNo idea, Ansys tutorials or from other sources?
January 31, 2025 at 2:44 am
jijojose2024
Subscriberi cant say specifically but i hardly remember anyone using mass weighted average.... mostly youtube
January 31, 2025 at 10:08 am
Forum ModeratorArea weighted tends to be used for walls etc, ie non-flow surfaces and values. Mass weighted for flow.Â
So, on a wall I'd look at area weighted temperature. On a flow boundary I'd use mass weighted temperature as that will account for the small fast (or slow) region holding the most (or least) energy.Â
3402
1057
1051
896
877
