August 7, 2024 at 7:15 am
farzan
SubscriberHi,Â
For modeling the electrochemical processes involved in water electrolysis I need to impose the electrode gas generation rate as a function of electric current density on the electrode surface. 2-phase Euler-Euler model has been chosen for multiphase flow and the gas generation function, written in Named Expressions, is called in the mass source term of phase-2 in the cells adjacent to the electrodes. However the solution freezes after few itereations leading to the error:
Error at host: Internal error at line 2388 in file 'bc\src\profile.c'. Too many profiles
Interestingly, any function in the mass source term leads to the same error and it has nothing to do with the electric potential solution; even a function of temperature, pressure or any other variable produces the same error. Only if the gas generation rate is taken as constant then the solution continues without any problem.
Could this problem be related to Expressions? Any thoughts on this will be really appreciated as nothing could resolve this so far. Thanks.
August 7, 2024 at 9:13 am
Forum ModeratorIt's possible. Which version of Fluent are you using? Expression functionality has been expanding over the last few years but there are a few areas where UDFs are still more reliable.Â
August 7, 2024 at 9:28 am
farzan
SubscriberThanks for the reply. I am using Fluent 2023 R2.Â
I can write UDFs which does that, however I could not find any Macros in UDF manual which allows access to the values of electric potential and electric current densitiy for each cell. Do you know any macros using which I can read cells potential/current values or is there a manual for this? Thanks.
August 7, 2024 at 9:58 am
Forum ModeratorOK, try in 2024R2 and see how that goes.Â
I can only refer you to the UDF manual, check in Electro chemistry as most of what you're doing will use those macros.Â
January 10, 2025 at 5:42 am
su.lim
SubscriberCan i get udf maual too?
January 10, 2025 at 10:29 am
Forum ModeratorYes, click on Help in Fluent, or https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/main_page.html?lang=en
6029
