November 28, 2023 at 12:14 pm
rajendrapor
SubscriberHello All,Â
How can I extract the mass flow rate data at a cross-section of my geometry in a transient simulation?
I have tried to make a monitor of Report--->Flux----> Mass flow rate. However, it does not show any change in the mass flow rate with time.
I am simulating an oscillatory system with pressure as inlet BC.
November 28, 2023 at 3:19 pm
Forum ModeratorIf you plot images is the result changing?Â
November 29, 2023 at 1:49 pm
rajendrapor
SubscriberHi Rob. Thanks for the quick response.
I am using a sinusoidal pressure inlet udf as BC for my system. I want to extract the data at a particular cross section. But it remains at zero with the simulation time (as attached in the figure). By plotting the images, what exactly do you mean? Should I plot the contours?
November 29, 2023 at 3:36 pm
Forum ModeratorYes, velocity contours. If you didn't set the report up correctly (ie using an area value for a point monitor) it's very possible to get a zero value on the monitors.Â
November 29, 2023 at 3:52 pm
November 29, 2023 at 4:38 pm
Forum ModeratorThat looks like you have a velocity field. How is the report defined?Â
November 30, 2023 at 11:46 am
rajendrapor
SubscriberI have tried to make a monitor of Report--->Flux----> Mass flow rate, at a cross-section of my model geometry.Â
November 30, 2023 at 11:52 am
Forum ModeratorOn an iso-surface or a named mesh (interior) face? If you report mass average of velocity on that surface what do you get?Â
November 30, 2023 at 1:54 pm
rajendrapor
SubscriberI am trying to monitor the mass flow rate at the named (mesh-interior) face. I will monitor the mass average of velocity and let you know as soon as possible.Â
November 30, 2023 at 2:00 pm
Forum ModeratorNo need to monitor, just create the report and check the value. This is to get an idea of whether there is flow, ie if there's a problem with the model rather than the report. Similarly run the mass flow report at the current time and see what value is posted to the TUI.Â
December 1, 2023 at 9:40 am
December 1, 2023 at 10:12 am
Forum ModeratorIf you open the mass flow report there should be a calculate or display button. What value does that post to the TUI?
December 1, 2023 at 12:46 pm
rajendrapor
SubscriberIt is displaying 0 kg/s. However, at the inlet, I am getting a mass flow rate of 0.00053036776 kg/s.Â
December 1, 2023 at 1:12 pm
Forum ModeratorOdd, what about the outlet?
December 3, 2023 at 4:02 pm
rajendrapor
SubscriberThere is no outlet in the system. It is a closed system, in which the flow gets reversed.
December 5, 2023 at 10:10 am
Forum ModeratorOK, so why wouldn't mass flow be zero?Â
December 12, 2023 at 1:14 pm
rajendrapor
SubscriberMeaning thereby?Â
Due to the closed system, the mass flow rate is zero?
December 12, 2023 at 3:02 pm
Forum ModeratorYes, if the density is fixed then you should have a zero mass flux. What goes in comes out.Â
- The topic ‘Mass flow rate data extraction from Fluent.’ is closed to new replies.
6660
1313
