3D Design
3D Design
    • Roberto Granito
      Hello
      is it possible to do 3d markup between two steps?
      They are 2 versions of the same file, I would like to make a comparison.
      If it is possible I can send the files for a secure link and can you make me the video of the commands to use?
      Regards
    • Atharv Joshi
      Hello Roberto ,
      You can go through this video 3D markup in SpaceClaim - SpaceClaim Tutorials - Ansys Discovery Forum. Use Assembly to insert the part instead of what's shown in the video and let me know if this helps.
      Else I will share the secure link with you and create a new video.
      Thanks and Regards
    • Roberto Granito
      Hello Atharv Joshi
      The video you sent me is not useful to me as I already have the two files that I have drawn in step , and I have to compare them , is it possible ?
      Regards
    • Atharv Joshi
      Hello Roberto ,
      I have shared the secure link. Please upload the model and I will look into it.
      Thanks and Regards
    • Roberto Granito
      Hello Atharv Joshi
      if you can let me know for tomorrow, do me a favor as the customer urgently needs to know if it can be done
      Regards
    • Atharv Joshi
      Roberto , Sure. I will let you know by tomorrow.
    • Atharv Joshi
      Hello Roberto ,
      Unfortunately, you won't be able to compare 2 already created files by 3D markup as the connectivity is lost. If you make changes to the original file in SpaceClaim and save it as a new version, then it remembers the original file.
      In such case 3D markup will help you compare 2 files and mark the changes in different colour.
      Thanks and Regards
Viewing 6 reply threads
  • The topic ‘Markup 3D’ is closed to new replies.
