August 13, 2024 at 11:11 am
August 16, 2024 at 11:35 am
Shuangxing Du
Ansys EmployeePlease define the upper deck by the non-diffraction panels. It may indicate the upper deck panes are out of water if the hydrodynamic pressures on those upper deck panels are zero.
August 16, 2024 at 11:39 am
w.s.syafruddin2
SubscriberCould you please explain how to define it step by step?
Thank you -
August 16, 2024 at 11:45 am
Shuangxing Du
Ansys Employee(1) Define the upper deck of the ship as the surface in Geometry which normal vector points upwards, together with other hull surfaces. See 5.2. Attach Geometry (ansys.com)
(2) Do the meshes in Aqwa Editor.
August 27, 2024 at 1:47 pm
August 27, 2024 at 4:11 pm
Shuangxing Du
Ansys EmployeeAll the pressure results are written into a binary file with the extension name of .PRS in your project folder. This file can be accessed by AqwaReader to get the panel pressureres at the required time step. Please read AqwaReader manual for further instrunction.
5799
