January 28, 2022 at 4:52 am
FluxLimited
SubscriberLet's say I want to run a steady state thermal calculation followed by a static structural calculation to determine the thermal stresses. I can link the two analyses in Workbench and run them successfully. But let's say I wanted to run the mechanical calculation on a geometric subset of the original thermal problem's geometry. How would I accomplish this?
January 28, 2022 at 9:15 amVinayak Vipradas
You can use Submodelling for modeling the geometric subset of the original geometry by linking the Solution Cell of the entire geometric Model to the Setup Cell of the Geometric Submodel. Make sure to include all the necessary boundary conditions in the Submodel. Then you can link the Solution obtained in the Submodel to the Static Structural Analysis, depending on what you want to import in the Static Structural Analysis.
For further information, please refer to the following links:
Performing Submodeling in Ansys Mechanical - YouTube
Linking Thermal Results as Input to a Thermal-Stress Simulation in Ansys Workbench - YouTube
Vinayak
Ansys Help
Ansys Learning Forum (Rules & Guidelines)
Viewing 1 reply thread- The topic ‘Mapping thermal load to a subset of the geometry in a mechanical calculation’ is closed to new replies.
Innovation SpaceTrending discussions- The legend values are not changing.
- APDL, memory, solid
- Meaning of the error
Top Contributors-
4042
1461
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
