TAGGED: 2-fsi, error, fsi-2-way, transient-structural
January 5, 2025 at 6:14 pm
omid.sarbakhshian
SubscriberI am trying to run a FSI model with fluent and transient structural and get the following error in transient structural
 MAPDL is unable to connect to the system coupling service on      Â
 DESKTOP-FAM6L5S.ozyegin.edu.tr through port 53187.  Check the -schost  Â
 and -scport options on the MAPDL command line in the System Coupling  Â
 analysis and ensure that the host name and the port number are     Â
 correct. -
January 6, 2025 at 9:49 am
harshvardhan.negi
Ansys EmployeeHi,
Here is a FAQ similar to your problem:
When I start a System Coupling analysis, I get error messages similar to the following (but maybe with a different port number): CFX: — ERROR #001100279 has occurred in subroutine ErrAction. Message: ANSYS CFX is unable to connect to the system coupling service on 0.0.0.0 through port 49755. Please ensure that the host name and the port number are correct. Mechanical: — *** FATAL *** CP = 1.388 TIME= 13:45:41 MAPDL is unable to connect to the system coupling service on 0.0.0.0 through port 49755. Please check ANSYS execution options -schost and -scport for a System Coupling analysis and ensure that the host name and the port number are correct. I checked that the port is not blocked by my firewall. What could be the reason for the failure? | Ansys Knowledge
I hope this helps.
Harshvardhan
Ansys Help
Ansys Learning Forum (Rules & Guidelines)
5804
