mapdl.cp limited to 20 points
    • Ramon Frey
      I'm trying to couple the y-degree of freedom of a set of nodes using pymapdl, but the function seems to be limited to 20 points:
      mapdl.cp(8, 'uy', nodes[0], *nodes[1:])
      Error:
      TypeError: CoupledDOF.cp() takes from 1 to 20 positional arguments but 32 were given
      First of all, it doesn't make sense to me at all why there would be such a limitation implemented. Second, is there a way to work around this?
      Any help is appreciated
    • erik.kostson
      Hi
      Looks strange the CP command (see MAPDL.CP() command in pymapdl site: https://mapdl.docs.pyansys.com/version/0.68/mapdl_commands/prep7/_autosummary/ansys.mapdl.core.Mapdl.cp.html)
      In general I would select all these set of nodes (e.g., nsel or cmsel commands), and then just use cp,next,uy,all, so:
      mapdl.cp(“NEXT”,”UY”,”ALL”)
      print(mapdl.cplist(“ALL”))
      All the best
      Erik
  • The topic ‘mapdl.cp limited to 20 points’ is closed to new replies.
