Ansys Products
Ansys Products
MAPDL and fatigue tool
    • filippobarbagelata07
      Hello everyone,
      I'm having trouble with the ansys mechanical built in fatigue tool.
      My static structural simulation to use to perform the fatigue analysis presents some numerical singularity making the equivalent stresses reach high values in some small zones.
      My idea was to write a MAPDL code that rrecognises the values over a certain tress that are effected by the singularity and overwrites the solution in the database with realistic values resulting from a linear interpolation of the resulting stresses in the zones wich do not present this singularity.
      The problem is:
      the code works fine, and it assigns the correct values to the critical nodes, but now I need to display the udated results in the ansys mechanical tree and launche the fatigue analysis with the updated data and I don't know how to do that specifically.
      Is there a MAPDL command that updates the results shown in the tree or is there a way to export the updated stress results and use them to perform a fatigue analysis in a separate workbench analisys?
      Thanks to anyone who will reply
    • Harshvardhan
      This is a duplicate post. I shall be closing thus post. The discussion on original thread can be found here:
      Harshvardhan
      Ansys Help
      Ansys Learning Forum (Rules & Guidelines)
  • The topic ‘MAPDL and fatigue tool’ is closed to new replies.
