September 27, 2017 at 11:19 am
nselvara
Ansys EmployeeHow do I make my model transparent, but not wire frame?
October 17, 2017 at 7:37 am
Arun Kumar
Ansys EmployeeAfter selecting the solid, try the following: §Select Color from the Design group, and then click the Opacity bar to change the opacity of the model. §Use the Color or Style Override tools, located in the Style group on the Design tab to set opacity for selected objects. Style Override makes the object opaque or transparent, regardless of face or layer settings. These overrides are automatically deselected when you change the transparency of an object using the Color tool or Style Painter.
October 20, 2020 at 8:25 pm
AJKINGE121
SubscriberIn Ansys 18.1 Mechanical Module. In the left tree Project--> Model --> Geometry ---> Body. Click on the body, n
nthen in Details of the body in the lower left side, Navigate in the Graphics Properties, there is the option called as transparency. n
nn
- The topic ‘Make my model transparent, but not wire frame’ is closed to new replies.
