Materials
Materials
Topics related to Granta Design and more.
Magnitude error
    • Mauricio Casarotto
      I have the following script to model and study an isotropic hardening model:
      FINISH
      /CLEAR
      !Asignando nombres al analisis
      /FILNAME,viga-ep-script,1
      /Title,Analisis-ElastoPlastico
      !Definiendo unidades (m,kg,s,K)
      /UNITS,SI
      !Entrando al preprocesador
      /PREP7
      !Definiendo tipo de análisis
      ANTYPE,STATIC,NEW
      !Definiendo propiedades del material
      MAT,1
      MP,EX,1,2E11
      MP,PRXY,1,0.3
      TB,BISO,1
      TBDATA,1,4E8,1E9
      !Definiendo keypoints
      K,1,0,0,0
      K,2,0.003,0,0
      K,3,0.003,0.001,0
      K,4,0,0.001,0
      !Definiendo lineas
      LSTR,1,2
      LSTR,2,3
      LSTR,3,4
      LSTR,4,1
      !Definiendo area
      A,1,2,3,4
      !Definiendo nodos
      NKPT,1,1
      NKPT,13,2
      NKPT,65,3
      NKPT,53,4
      FILL,1,13
      FILL,13,65,3,26,13
      FILL,1,53,3,14,13
      FILL,14,26
      FILL,27,39
      FILL,40,52
      FILL,53,65
      !Definiendo elemento
      ET,1,PLANE182,0,,2,,,1
      !Asignando malla al area
      AATT,1,,,,1
      !Estableciendo la malla
      MSHAPE,0,2D
      MSHKEY,0
      LESIZE,1,,,12
      LESIZE,2,,,4
      LESIZE,3,,,12
      LESIZE,4,,,4
      AMESH,ALL
      NUMMRG,NODE
      !Estableciendo las cargas y restricciones
      D,1,ALL,0
      D,14,UX,0,,53,13
      D,65,UX,0
      D,65,UY,-0.001
      !Iniciando el solucionador
      /SOLU
      !Incluyendo no linealidades
      NLGEOM,ON
      AUTOTS,OFF
      DELTIM,1
      NSUBST,80
      KBC,0
      !Solucionando
      OUTRES,ALL,ALL,,,,
      SOLVE
      FINISH
      /POST1
      SET,LAST,80
      PLDISP,1
      PLNSOL,S,EQV,0
      PLNSOL,EPPL,EQV,0,,,,AUTO
      PLNSOL,EPTO,EQV,0,,,,AUTO
      /POST26
      !Curva U-L
      NUMVAR,200
      TIMERANGE,0,1
      NSOL,2,65,U,Y,DESPLAZAMIENTO
      XVAR,2
      ABS,2,2,,,DESPLA,,,1
      PLTIME,0,1
      ESOL,3,48,65,F,Y,CARGA
      /AXLAB,X,DISPLACEMENT
      /AXLAB,Y,LOAD
      PLVAR,3
      While the deformed shape is right and compares to the ones in previous studies, when I graph the load vs displacement I get the right numbers but a thousand times bigger than the previous studies. The values of forces should be  in the range of 60 to 65.
      I dont know what am I doing wrong.
    • Chandra Sekaran
      My guess is that it must be something inconsistent with the units. Can you add units as comments to the input deck? What is the reference you are comparing to?
  • The topic ‘Magnitude error’ is closed to new replies.
