Electronics
Electronics
Magnetization issue about ANSYS maxwell
    • Michael Doherty
      I have two models, the 1st is for demagnetization calculation and the permanent magnet field link is set in the 2nd one, they share the same geometry.
      In the 1st one, the demagnetization calculation is activated, and the set as follows:
      In the 2nd one, I tried to link it with the 1st model. As there are several permanent magnet pieces, and I only wanna one of them link to the 1st model. So I tried the object based permanent magnet field by selecting the object > assign excitation >permanent magnet field.  The demagnetization calculation is cancelled in the 2nd model. All of my settings are shown below.
      Errors:
    • HDLI
      Hello Michael,
            Could you save or copy this model to another local drive, not in documents, Onedrive or network drive? Documents folder may be synched with Onedrive, so it is also network folder.
            Please make a short name, if possible.
            Please delete solution with linked data. Thanks.
      HDLI
  • The topic ‘Magnetization issue about ANSYS maxwell’ is closed to new replies.
