Electronics
Electronics
Magnet Demagnetisation and B field at each time step
    • sana ullah
      HI I am trying to find the demagnetisation in the magnets, do i have to use the demag_Coeff to find it out? Also I am finding it hard to find the B field at each time step, its showing only the B field at the last time step? What can i do to make the B field shown across the rotor and stator at each time step?
      Kind regards
    • Chinmay Telkikar
      First, you need to set the demagnetization computations by clicking on Maxwell>Excitations>Set Magnetization Computation.
      Then, you can plot Demag_Coe by selecting objects, right-clicking them, and selecting Fields>Other>Demag_Coef.
      To visualize the fields at each time step, please enable the save fields option on the General tab of the Solve Setup dialog box.
      Thanks,
      Chinmay
    • sana ullah
      Dear Chinmay
      Thank you very much for your help. I followed the following procedure for degmanization findings, you think its correct ?
      1) Maxwell2D--> Excitations --> Set Magnetization Computation --> Compute demagnetised operating points (pic shows how the options look like)
      kind Regards
      Sana
    • Chinmay Telkikar
      Hello sana ullah,
      The option you have selected in the Set Magnetization Computation window is correct.
      Thanks,
      Chinmay
    • sana ullah
      Thank you very much Chinmay
Viewing 4 reply threads
  • The topic ‘Magnet Demagnetisation and B field at each time step’ is closed to new replies.
