May 20, 2026 at 8:23 am
viki.kohad
SubscriberI am getting the following error while running the Machine Toolkit on local configuration:“Incorrect input files to postprocessing”Please note that there is no use of LS-DSO in this setup, and the simulation is being run on the local configuration only.Also, I have tried both:Direct AnalysisSplit AnalysisHowever, the issue still persists.
Viewing 0 reply threads
1310
