TAGGED: cfd-combustion, compressible-flow-air, fluent, hypersonic
October 10, 2024 at 6:31 pm
zoelle.wong
SubscriberI am modelling an ionizing, supercrticial flow. Under "materials", the fluid's thermodynamic properties are being calculated through a UDF and the density is calculated using the Peng Robinson Equation of State. I am using a pressure solver, because my back-of-the-envelope calculations indicate that the maximum speed is M<1.0
Mach number for an ideal, calorically perfect gas is commonly known as the U_infty/sqrt(\gamma R T), where speed of sound, a = sqrt(\gamma R T). But for a real flow, a^2 = \partial p/ \partial \rho |s = \gamma \partial p/ \partial \rho |_T (image below)
When post-processing my results, I can create a Mach contour plot. But how is ANSYS fluent computing the mach number and speed of sound in the backend? Is it computing the speed of sound as a change of pressure and density for each cell? What kind of numerical schema does it use if it does compute the speed of sound as a function of pressure and denstiy for each cell? When reading through the theory manual, it doesn't provide these kinds of details. Thank you so much in advance!
October 15, 2024 at 2:26 pm
Essence
Ansys EmployeeHello,
Yes, Fluent uses the equation as displayed in the image to determine speed of sound for real fluids.
5649
1885
1404
1303
