Lumped and consistent mass matrix
    • Uzairsain
      Hello ,
      Ansys mechanical uses which method lumped mass matrix or consistent mass matrix to solve vibration problems and why?
    • Erik Kostson
      Hello
      In general most 3D elements should use the consistent matrix by default - with the LUMPM one can generate a lumped mass matrix, but there are some limitations and complications so look this up in the help manual - thus LUMPM should be used with care.
      Search in our help manual (e.g., lumped and consistent and mass - and LUMPM command) and you will find hopefully some info about this.
      Hope it helps.
      All the best
      Erik
    • Uzairsain
      thank you sir
    • Erik Kostson
      You are more than welcome - all the best for now.
      Erik
  • The topic ‘Lumped and consistent mass matrix’ is closed to new replies.
