October 30, 2024 at 1:15 pm
ashish.singh
CONFIGURATION FILE {'root': 'C:\\\\Program Files\\\\Lumerical\\\\v242\\\\api\\\\python', 'lumapi': 'C:\\\\Program Files\\\\Lumerical\\\\v242\\\\api\\\\python'}
Traceback (most recent call last):Â File ~\AppData\Local\anaconda3\Lib\site-packages\spyder_kernels\py3compat.py:356 in compat_exec
  exec(code, globals, locals) File c:\users\ge83sax\desktop\optimization\opt.py:90
  geometry = FunctionDefinedPolygon(TypeError: FunctionDefinedPolygon.__init__() got an unexpected keyword argument 'unfold_symmetry'
please help me outÂÂ
October 30, 2024 at 5:20 pm
anna.wirth-singh
Ansys EmployeeHi Ashish,
I'm sorry to hear you are having issues with lumopt. Can you please provide some more information about the line geometry = FunctionDefinedPolygon(arguments) ? I am not able to see the function arguments in the post, so perhaps you can paste the code in plain text. That will help to diagnose the problem.Â
Here is an example of how a geometry can be defined:
geometry = FunctionDefinedPolygon(func = your_function,
                 initial_params = initial_params,
                 bounds = bounds,
                 z = 0.0,
                 depth = depth,
                 eps_out = eps_out,
                 eps_in = eps_in,
                 dx = 1.0e-11)Â
Where 'your_function' is a function you have written to return the points in a polygon, ordered in a counter clockwise direction.
I do not see 'unfold_symmetry' as one of the keywords of FunctionDefinedPolygon, so that is likely where the error is coming from. The available keyword parameters are listed here: Geometries — LumOpt documentation
Best,
Anna
November 6, 2024 at 3:31 pm
ashish.singh
Subscriber# Define the geometry function to keep each ring separate
def concentric_rings_function(params):
  central_radius = params[0]  # in meters
  gap_width = params[1]    # in meters
  period = params[2]      # in meters  verts = []
  for i in range(n_rings):
    # Calculate inner and outer radii for each ring
    r_inner = central_radius + i * period - gap_width / 2
    r_outer = central_radius + i * period + gap_width / 2
    num_sides = 64000 # Increased number of points for smoother rings
    angles = np.linspace(0, 2 * np.pi, num_sides, endpoint=False)
    # Define outer and inner vertices for each ring
    outer_vertices = np.array([[r_outer * np.cos(theta), r_outer * np.sin(theta)] for theta in angles])
    inner_vertices = np.array([[r_inner * np.cos(theta), r_inner * np.sin(theta)] for theta in angles])
    # Close the ring by appending the first point at the end of each ring
    ring_vertices = np.vstack((outer_vertices, inner_vertices[::-1], outer_vertices[0:1]))
    verts.append(ring_vertices)  # Keep each ring separate in the list  return verts  # Returns a list of arrays, each array representing a ring
  return np.array(verts)  # Convert the list to a numpy array with consistent shape
# Create the FunctionDefinedPolygon geometry
  func=concentric_rings_function,
  initial_params=initial_params,
  bounds=bounds,
  z=gold_thickness+sio2_thickness+(gaas_thickness/2),
  depth=gaas_thickness,
  eps_out=1.0 ** 2,     # Dielectric constant outside the rings (e.g., air)
  eps_in=3.47668 ** 2,    # Dielectric constant inside the rings (e.g., GaAs)
  edge_precision=5,     # Precision of the polygon edges
  dx=1.0e-5,  Â
  unfold_symmetry=False,        # Spatial resolution for the polygon
)# === Define ModeMatch FOM ===
# Initialize ModeMatch with the specified monitor name
mode_match_fom = ModeMatch(
  monitor_name='fom',          # Exact monitor name as in Lumerical FDTD simulation
  mode_number=1,            # Mode number to calculate overlap with
  direction='Forward',         # Propagation direction ('Forward' or 'Backward')
  multi_freq_src=False,         # False for single frequency mode calculation
  target_T_fwd=lambda wl: np.ones(wl.size),  # Target transmission function
  norm_p=1,               # p-norm for figure of merit calculation (1 for standard FOM)
  target_fom=0             # Target value for FOM (optional)
)# === Define Wavelength Settings ===
wavelengths = Wavelengths(start=1.2e-6, stop=1.6e-6, points=100) Â # Define the wavelength range and points# === Define Optimization Algorithm ===
optimizer = ScipyOptimizers(
  max_iter=50,
  method='L-BFGS-B',
  scaling_factor=1e9,         # Scales parameters from meters to nanometers
  pgtol=1e-6,
  ftol=1e-6,
  scale_initial_gradient_to=0.0,
  penalty_fun=None,
  penalty_jac=None
)# === Setup and Run Optimization ===
# Define paths and parameters for optimization
base_script_path = 'cbg2.lsf' Â Â Â Â Â # Path to the Lumerical script file
geometry = None             # Define your specific geometry hereopt = Optimization(
  base_script=base_script_path,    # Path to Lumerical script for simulation setup
  wavelengths=wavelengths,      # Wavelength settings for simulation
  fom=mode_match_fom,         # Figure of Merit (FOM) configuration
  geometry=geometry,         # Geometry configuration, like concentric rings
  optimizer=optimizer,        # Optimizer configuration
  use_var_fdtd=False,         # Use standard FDTD rather than VarFDTD
  hide_fdtd_cad=False,        # Whether to hide the FDTD CAD window
  use_deps=True,           # Use FDTD’s numerical derivatives
  plot_history=True,         # Plot optimization history
  store_all_simulations=True,     # Store all simulation results from each iteration
  save_global_index=False,      # Save global index monitor results (optional)
  label='Bullseye Structure Optimization',  # Label for the optimization project
  source_name='source'        # Name of the source in the Lumerical simulation
)# Run the optimization, saving results to the specified working directory
working_directory = os.path.join(os.path.dirname(__file__), 'optimization_results')
opt.run(working_directory=working_directory)
this is the code i am using i want to optimize a structure using RCWA which as multiple parameters which i need to optimize. Any insight or help will be greatly appreciated -
November 11, 2024 at 9:42 pm
anna.wirth-singh
Thank you for providing your code. From my understanding, lumopt was built to work with FDTD (a time-domain algorithm) and I am not sure it will work for RCWA (a frequency-domain algorithm) without substantial modifications.Â
Have you considered using the built-in optimization utility? Please see: Optimization utility – Ansys Optics. This utility can be called from the script as shown in this example: Creating optimization tasks using a script – Ansys Optics. I think this would be more straightforward to set up than lumopt.
I think you could define a Structure Group to build your structure from script: Structure Groups - Simulation object – Ansys Optics. Defining an Analysis group would be the best way to define a custom figure of merit. In the Analysis group script, you can perform calculations and if you specify those variable to be results, then they can be used as FoM for optimization. Could you tell me a bit more about the figure of merit you want to optimize? In your script, it looks like you are using the ModeMatch FoM, which is mostly applied to waveguides. Do you want to optimize the transmission through the structure?
While this example is not for RCWA, this example has both an analysis group and an optimization that uses the result from that analysis so it will be useful to have a look:Â
Plasmonic gap waveguide – Ansys Optics
Best,
Anna
