December 12, 2024 at 2:07 am
limy
Subscriber如果我的主板支持多路GPU,例如我使用三张相同的显卡,可以实现显存扩展,那么Lumerical GPU计算的可用显存是否也能实现扩展?如果我使用两张不同的显卡,是否因为会驱动版本不同只能调用一张显卡?
December 17, 2024 at 6:56 am
Zheng Zhou
Ansys Employee您好,可以参考:Getting started with running FDTD on GPU
- Multi GPU support is available on 1 machine (local host) in Linux. It is not supported on Windows.
- Multi GPU across/spanning several machines/nodes is not supported.
